It is currently Fri 19. Apr 2024 18:36:43
 Post subject: DX9 with SPM4649T
PostPosted: Sun 20. Aug 2017 19:24:28
Hi Thomas,
I just setup my heli for telemetry with spektrum intigration.
When I bind the radio voiced bound with telemetry, I get signal strength from the rx but nothing else. I also cannot get into the settings menu from the blank screen.
Ritchie
 Post subject: Re: DX9 with SPM4649T
PostPosted: Sun 20. Aug 2017 19:34:41
What ESC do you have? Different ESC use different telemetry cable. Also is the 4649T sending signals to Spirit, like if you go in diagnostic page can you see your stick inputs going to Spirit?
Also check:
1) Spirit flashed with new firmware and bootloader
2) Correct telemetry type selected in Spirit setup advanced menu
3) DSMX mode selected in Spirit setup
4) 4649T connected to Spirit in correct way per setup guide
PostPosted: Sun 20. Aug 2017 19:41:40
Also check:
I have flashed the firware, where do i find the bootloader ?
I have not connected the esc telemetry as yet as I more interested in changing settings from my radio.
The 4649 is connected as per the insructions, the heli operates fine
Ritchie
PostPosted: Sun 20. Aug 2017 19:44:08
when you connect only SPM4649T (no satellites) can you see that a channels are moving? (you can control the model).
I guess that yes.
Then the problem could be in the radio firmware. Is it at 1.20 version?
Bootloader can be flashed as per instructions in the Spektrum guide here:
http://manual.spirit-system.com/index.p ... nding_mode
PostPosted: Sun 20. Aug 2017 19:49:12
I guess that yes.
Yes I can control the model and it shows in the spirit software.
I have updated the radio to 1.2
The rx is not permanently in bind mode so i havent done the boot loader
Ritchie
PostPosted: Sun 20. Aug 2017 19:54:31
Ah, so when you go to the ESC Status page, you can't even see that Throttle value is changing there?
Do you see --- instead of values or at least 0 values?
PostPosted: Sun 20. Aug 2017 20:04:00
How very strange, I just simply created a new model, bound that and it works fine !!!
On another note, If i connect my esc via the sat port, i assume i will not then be able to use a sat as well as the receiver ? I have the original spirit unit with only one sat port.
Ritchie
PostPosted: Mon 21. Aug 2017 0:34:54
That is correct. If your ESC requires telemetry cable going into sat port then you can't run sat with Spirit, and only 1 sat with Spirit Pro.
Users browsing this forum: No registered users and 52 guests
