It is currently Thu 18. Apr 2024 19:56:12
PostPosted: Thu 21. Jun 2018 3:31:17
Hi, I need some help / guidance with the wiring to use the HW SCM module please.
I'm using a Spirit Pro, SPM4649T and a HW 200A ESC. Should I connect the throttle lead through the SCM ? Should I take the +, - from the Aux port on the ESC anywhere ?
Attached is the manual for the the SCM module.
RPM_Telemetryen_Manual.pdf [1.47 MiB]
Downloaded 69 times
PostPosted: Sat 23. Jun 2018 1:40:45
Bump. Help needed please !
PostPosted: Sat 23. Jun 2018 16:22:20
you do not need the SCM module.
But it could improve RPM or telemetry connection.
Unfortunately I can answer your question on monday. I hope it is OK.
Is there any problem you are having right now?
PostPosted: Sat 23. Jun 2018 18:07:25
Thanks for the reply.
I get all the telemetry values, except mah consumed.
Monday, no problem. Thanks in advance
PostPosted: Mon 02. Jul 2018 3:47:57
Maybe this Monday ? ;) :lol:
PostPosted: Mon 02. Jul 2018 7:44:14
I am very sorry for delayed reply.
You can connect it according the manual that you have attached.
Throttle signal can be connected directly to the AUX port of the unit while Telemetry data should be connected through this SCM module.
This module is designed mainly for RPM and Telemetry data ports of the ESC. But if you do not use RPM lead you do not have to connect it anywhere.
Users browsing this forum: Bing [Bot] and 16 guests
