It is currently Wed 23. Jan 2019 9:55:39
PostPosted: Thu 07. Dec 2017 8:35:26
Hi Thomas,
Can you give more details on how the governor works in a nitro setup? I have a Trex 700N and have set up the governor and throttle according to the instructions in the manual and the wiki page. Setting it up is ok, but understanding how to operate it is difficult to understand. I searched all over but could not find useful information.
Can you describe how the governor is implemented with the following questions?
Can it be switch on/off or activate/deactivate in the Transmitter/Radio?
Do I still setup up a throttle curve and;
if the governor fails, does it fall back to the throttle curve?
How do I implement different head speeds?
In what range is the governor activated or at what percentage does the governor activate?
Thank you.
PostPosted: Thu 07. Dec 2017 9:53:43
Hi!
Please check this page:
http://manual.spirit-system.com/index.p ... ransmitter
Regarding answer about governor failing you can find it here (at the bottom):
http://manual.spirit-system.com/index.p ... e=Governor
