It is currently Thu 28. Mar 2024 23:56:28
 Post subject: Version 2.1 released!
PostPosted: Sun 21. Aug 2016 10:06:26
Version 2.1.0 was released!
It brings many new features and improvements:
  • Major governor algorithm improvements:
    • Performance was greatly enhanced by adding dynamic factor into the regulation loop.
    • Governor is not dependent on the RPM Sensor anymore.
    • In case of RPM Sensor malfunction, governor will still work (with lower performance).
    • RPM Sensor failure reported in the Log.
    • RPM data noise detection feature is more precise. It can distinguish a real noise in a better manner.
    • Head speed can be changed in any situation with no performance influance.
  • Realtime Tuning feature:
    • Brand new feature that will allow you to set 20 parameters and 4 functions from any transmitter!
    • Possibility to assign 3 different realtime parameters and functions at the same time.
    • Support for Channel data pass-through to the CH0 servo output.
    • Support for Vibration Analysis during flight (In-Flight).
    • Parallel usage along with the Bank Switching or Jeti Integration with no problems.
    • Please check the Online Manual for more details.
  • Adaptive Rudder stopping algorithm:
    • Stopping behavior is automatically enhanced during flight to gain the best performance.
    • Stopping is automatically updated for both sides separately.
    • If overshooting is detected, it will be eliminated as possible.
  • Channel layout:
    • Support for 10 channels (Spektrum DSM2/DSMX, Futaba S-BUS, SRXL/SUMD, Jeti EX Bus).
    • Support for 8 channels (PPM).
  • Futaba S-BUS protocol:
    • Possibility to set Failsafe directly in the unit (Channels window).
  • Jeti EX Bus protocol:
    • Order of telemetry data was changed to make it compatible with DeviceViewer software (Please refresh telemetry variables in your transmitter).
  • Spektrum DSM2/DSMX protocol:
    • Fixed compatibility with Wifi-Link module - unwanted Binding problem.
  • Setup Wizard:
    • Helicopter profiles were updated (Oxy 3, Goblin 380).
    • Connection reliability was improved for the USB interface and Wifi-Link.
  • Rescue safety protection:
    • When initialized with engaged Rescue mode, the swashplate will signalize the event (Warning by Pitch-Pumps in the loop).
  • Software improvements:
    • Tooltips with more details.
    • Connection was improved when transmittion is unstable.
    • Minor useability tweaks.
You do not have to change any settings after the update from previous version.
Only minor tuning of the Governor Response and Holding performance parameters might be needed.
Futaba S-BUS users should set Failsafe in the General/Channels.
Update for the Spirit unit, Wifi-Link and Jeti Integration is available in our Download section.
