It is currently Mon 03. Jun 2024 22:10:38
PostPosted: Fri 09. Oct 2020 20:09:07
New version 3.2.0 released!
  • Brand new Quick Flashing Process:
    • From now you can flash new firmwares more smoothly, faster and reliable.
    • Firmware flashing can take just 7 seconds!
    • Once flashed, new firmware will boot up instantly with no need for re-power.
    • All settings are preserved as usually.
    • New Flashing Procedure will take effect after 3.2.0 update. Then next updates will be much faster.
    • Incorrect firmware flashing is not possible anymore.
    • NOTE: Transition from older firmwares is the most important to complete properly.
    • NOTE: Make sure that your computer can flash firmwares properly prior this upgrade. This is required only for this update, since old flashing method is still used (only first time).
    • NOTE: We recommend for Mac OS X users to make this transition on a Windows or Linux computer due to known driver issues. After this update, updating with Mac will be perfectly safe.
    • NOTE: If you want to downgrade to an older version, it is possible to obtain old compatible version upon request. Original old firmwares will not work.
  • New easy Recovery mode:
    • In case that firmware flashing was interrupted for whatever reason, Spirit unit will boot up in recovery mode automatically.
    • You can finish the flashing once unit will start to blink with LED quickly.
    • Enter Recovery Mode when Status LED is blinking quickly, select firmware and just press the Flash button.
  • Futaba SBUS/SBUS2 enhancement:
    • Each data frame is examined to match correct time synchronization.
    • Additional protection from corrupted packets.
  • Support for three SRXL2 satellites:
    • From now Spirit 2, Spirit RS, Spirit Pro and µSpirit units can be interfaced with additional satellites.
    • You can connect them at the satellite ports with SRXL2-satellite adapter.
    • NOTE: We still recommend to use full size receiver + satellite receiver together.
  • Improved Spektrum Integration:
    • Entering and closing the Integration menu is now more intuitive.
    • Only once menu is completely closed with sticks, you will see CLOSED label.
    • During closing you will see CLOSING label.
  • Improved detection of SPM4649T receiver:
    • Receiver is now detected properly so that integration should work always well with all Spektrum radios.
  • Spektrum DSM2/X protocol:
    • Spektrum satellites are switched faster on signal loss.
    • Temporal signal loss during satellite switch is only 100ms long.
  • JETI telemetry tweak:
    • S RPM parameter has RPM extension after value.
    • This can be usefull for voice speech output.
  • HobbyWing ESC telemetry:
    • Temperature will corelate with ambient ESC temperature now.
  • µSpirit - Rudder ESC motor:
    • Motor will turn on immediately when Throttle function is assigned and Low RPM parameter is configured.
  • New Anti-Gravity feature:
    • This feature is modifying Collective Pitch steering to gain lighter feeling of the model.
    • When model is skids down, bottom half of the pitch has not that impact. Model will not descend that quickly.
    • In other words with 50% value you will obtain +12° but only -6° for negative side.
    • This is especially useful for smaller helicopters of 250 class and smaller.
    • This parameter is not changing Collective Pitch range. So you do not have to make any other adjustments.
    • New parameter is located in the Expert Settings.
  • GeoLink features and Rescue mode:
    • From now Rescue Duration parameter will take effect with GeoLink features engaged.
  • Spirit Settings - Messages:
    • Spirit Settings software will let you know what is needed to do in unusual scenarios (Version Mismatch, Updating)
  • Spirit Settings - Log Viewer:
    • Fixed problem with a non standard Documents directory location.
    • Logs should always open whenever Documents directory is located.
  • Spirit Settings - In-Flight Vibration Analysis:
    • Vibration Analysis can be selected for any Special Function.
    • Previously only first 3 Special Function assignments allowed to see In-Flight option in the Analysis window.
No need to change any parameter after update from version 3.1.
WARNING: Make sure that your computer can flash firmwares properly prior this upgrade. This is required only for this update, since old flashing method is still used (only first time).
WARNING: We recommend for Mac OS X users to make this transition on a Windows or Linux computer due to known driver issues. After this update, updating with Mac will be perfectly safe.
NOTE: This update must be performed with Spirit Settings 3.2.0.
Update for the Spirit units, Wifi-Link, JETI integration, OpenTX integration is available in our Download section.
PostPosted: Thu 26. Nov 2020 14:21:20
New version 3.2.1 released!
  • Quick Flashing Process update:
    • Updated instructions in the Spirit Settings after Flashing process.
    • In case flashing will not start normally, the software will repeat the process.
  • Futaba SBUS enhancement:
    • Improved compatibility with some FrSky receivers.
    • Improved compatibility with some Spektrum DSM2/X satellites for easier binding process.
  • Rescue mode - Rescue Duration:
    • When model is upside down and Rescue Duration passed, collective pitch steering is in the right direction in all cases.
  • Stabilisation and GeoLink modes enhancement:
    • When Stabi Correction feature is turned Off model can fly precisely with even higher vibrations.
  • GeoLink logging:
    • New possibility to turn off GeoLink logging in the GeoLink window/Module tab.
    • When logging is turned off, module can sustain higher electrostatic discharges.
    • By default Logging will be disabled starting with this update.
  • Spirit Settings - Setup Wizard:
    • Added new Tron 5.5 model preset.
No need to change any parameter after update from version 3.2.0.
Update for the Spirit units, GeoLink is available in our Download section.
WARNING: Update from 3.1.0 and older - Make sure that your computer can flash firmwares properly prior this upgrade. This is required only for this update, since old flashing method is still used (only first time).
WARNING: Update from 3.1.0 and older - We recommend for Mac OS X users to make this transition on a Windows or Linux computer due to known driver issues. After this update, updating with Mac will be perfectly safe.
