It is currently Wed 17. Oct 2018 21:08:03
PostPosted: Sun 30. Sep 2018 10:39:00
:( Hi Thomas, hope you can help me out to fix the problem. Going to upgrade one of my SpiritProV2 to the new (5.2.0) firmware and accidentally connect the USB interface into Ele/Pit/Ail port. The unit stop working since and could be damaged. Any possibility to fix it,very much appreciate and going to cover all the cost as long you can do something to it. Thanks mate...
Regards...
PostPosted: Sat 06. Oct 2018 13:07:35
don't worry. We can repair it without any problem.
Did you checked if the unit was still operating in some way?
Maybe there will be no damage, because connecting the USB interface to ELE/PIT/AIL should cause no damage normally.
It will be fixed quickly.
Users browsing this forum: No registered users and 1 guest
