It is currently Mon 03. Jun 2024 21:14:08
[ 3 posts ] |
Martin.S
Posted: Tue 22. Aug 2023 10:03:16 |
got a 100a YPG ESC connected on aux1 on the spirit2 but engine no signal the FBL is connected with a duo BEC from Mateck systems 6V to the RX end 8.4V for the FBL and servo's all KST FBL works al servo's working but on aux 1 no signal for the ESC on the software put the channel mapping to cannel 3 like it is on the TX Frsky X20. disconnect the red wire from the ESC( power is running on the externe BEC) some one nows the problen or give me a hint. regards Martin
Posted: Tue 22. Aug 2023 10:05:28 |
please set Channel for Throttle to 1.
I am not sure what is your receiver wiring but in the most cases it is Channel 1 in the Spirit. You should see throttle channel movement in the software in any case.
Martin.S
Posted: Tue 22. Aug 2023 14:43:29 |
reciever is a Jumper R1 sbus 16ch
[ 3 posts ] |
Users browsing this forum: No registered users and 5 guests |
