It is currently Wed 17. Apr 2024 0:28:51
PostPosted: Sun 24. Jun 2018 6:01:02
I have a Goblin 700 and the Spirit Pro set with wizard setup. But do not come to take off because the tail starts extremely shaky at higher speed. What must I change that is gone? Have already tried different cyclic gain and Rudder Common Gain values without success.
PostPosted: Wed 27. Jun 2018 7:47:31
you have to set Gyro Gain properly. It look like your gain is very high.
You can verify what gain is configured now in the Diagnostic tab. There you should see something like 50% which is recommended for the first flights.
What value you can see there right now?
PostPosted: Tue 04. Dec 2018 12:09:04
Hi
Take the multiplyer down to 1.0 instead of 1.5 as in present for the gob 700. Then gain at around 50 .this should work. I had the same problem and multiplyer at 1.5 was the problem.
